I'm currently using NetAdvantage 2009 Vol1 on IE 7. I have a grid where the first 8 columns are fixed using usefixedheaders = true. I have a column header that spans above these first 8 columns, I also have 7 other columns with another column header across those 7 columns. These 7 columns can scroll left to right. All of the columns have free column sizing. The problem is when I try to resize any one of the 7 column that are not fixed. When I resize 1 of the none fixed columns, some of the fixed columns also change sizes. I've had this probem since version 2008 Vol 2.
Eric
For anyone else that is interested. I heard back from support and column sizing is not supported when using header layouts. This is stated clearly in the online docs.
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2009.1/CLR3.5/html/Infragistics35.WebUI.UltraWebGrid.v9.1~Infragistics.WebUI.UltraWebGrid.UltraGridColumn~AllowResize.html
I'm still going to try to find a solution but it probably will not be anytime soon.
Xiaosu,
No, I haven't found a solution yet. I'm glad to see someone else is having the same issue. If I do find a solution I will post it here.
Hi Eric,
I got the same problem. Did you find the solution for that?
Thanks a lot.
Xiaosu
Sorry to bump this but it's been a week. I submitted a support request but my subscription has expired so I'm not sure if support will look at it or not. So I was hoping to give this one more chance.
