40
Updating SQL database with cell values from code
I have an UltraWebGrid with a Webcombo EditorControl with hidden columns containing the ID's of the related objects.  In the UpdateRow event I get the ID values from the selected row of the WebCombo and stuff them into the UltraWebGrid cells:
Protected
Sub ActsGrid_UpdateRow(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.RowEventArgs) Handles ActsGrid.UpdateRow
If e.Row.DataChanged
Then
'Updated
e.Row.Cells(24).Value = Now()
'MatterID and EventID
If Me.EventsCombo.SelectedRow IsNot Nothing
Then
Dim evid As Integer = Me.EventsCombo.SelectedRow.Cells(0).Value
Dim matid As Integer = Me.EventsCombo.SelectedRow.Cells(1).Value
e.Row.Cells(6).Value = evid
e.Row.Cells(7).Value = matid
The correct values are arriving safely into the row.cells, but the integer values are not being saved into the SQL database.  The DateTime value is correctly saved. My SQLDataAdapter INSERT query includes the parameters from these cells.  How do I save these values??
thanks
End
If
  • 4555
    The values in the UltraWebGrid should contain the correct values, even for the WebCombo. If you  have defined a DataValueField and a DataTextField then the grid's cell's value should be be that of the  DataValueField and this can be used for updating the DataBase.
    Magued
