85
Infragistics Text Wrap Problem in Version 7.1
Hi
I am using infragistics Ultragrid 7.1 version. If I reduce the column size, then the text in the cell is not wrapping.
http://samples.infragistics.com/2007.1/
Grid à Navigating &selecting à Row –Column selection –sample program given in the website.
Please refer (image1) for the problem
Currently the column wrap feature is available in Infragistics 8.3.
URL: http://samples.infragistics.com/2009.1/WebFeatureBrowser/Default.aspx
But from the version 8.3 GridBehaviorCollection is added its having the below tag
<Behaviors>
                        <ig:ColumnResizing Enabled="true">
                            <ColumnSettings>
                                <ig:ColumnResizeSetting EnableResize="true" />
                            </ColumnSettings>
                        </ig:ColumnResizing>
                        <ig:Paging PagerAppearance="Bottom" PageSize="10" Enabled="true" />
                    </Behaviors>
I want to achieve the same feature in Infragistics 7.1.If so how could we achieve in Infragistics 7.1.
Use of latest infragistics will solve my problem? Please give your answer ASAP.
