Greetings,
I'm trying to write a drag and drop routine. I have a split pane with a tree on one side and a WebGrid on the other. When the user chooses a node from the tree and drags it to the grid, I want the row which the user hovers over to activate or become selected.
As it stands now this does not happen. It requires an actual click to high-light the row.
Anyone have ideas here?
Thanks!
Ok, terrific
In your Over function, it seems you have access to the cell...(cellID)
use the following to get the row
var cell = igtbl_getCellById(cellID);var row = cell.getRow();
if you also need the row id...although you've already got a reference to the row object with getRow();
// continuing on from abovevar rowId = row.Id;
that should be right for you to access the row when hovering...if you store the rowId, you will be able to tell when the mouse hovers over a new row instead of the cell in the same row, something like this:
//outside of hover functionvar lastHoverRowId;// in hover functionif (lastHoverRowID !== rowId) {
// the mouse has changed to a new row doStuff(); // store the new rowId lastHoverRowId = rowId; // store the value}
Terrific
While I have your interest, can you tell me how I would capture the 'row id' ? I will use the approach you directed but i'm wondering how I will be able to capture the row id using these methods.
For instance, I know there is something for cells:
function Over(gridNane, cellID, objectType) { var cell = igtbl_getCellById(cellID);
But how about the rows??
Have a look in the property grid under DisplayLayout for the client side events. You will find the MouseOutHandler, MouseOverHandler. I use those methods to handle hovering events in my grids so you should be able to work it out with that.
