410
Show/Hide Last Columns in UltraWebGrid
Hi All,
I have a grid with almost 15 columns so need horizontal scroll to display all the columns. Is there any property/method/way I can hide last 3-4 columns so that horizontal scroll bar is not displayed but it will add some sign [+] on last column & clicking on this sign will show remaining columns.
Thanks in Advance
  • 1923
    you could quite easily set the width of the columns to be very small and then provide a button (perhaps put the button in a toolbar etc) that says "Show All Columns" etc and when clicked it could then set the columns to be the larger size...
    Each column object client side has a setWidth(number) function which will set the size.
    You could in the InitializeLayout Server side event set the size of the last 3 or 4 etc:
        Protected Sub UltraWebGrid1_InitializeLayout(ByVal sender As Object, ByVal e As LayoutEventArgs) Handles UltraWebGrid1.InitializeLayout
            ' figure out the number of columns etc
            Dim NumColumns As Integer = UltraWebGrid1.Columns.Count
            ' loop through the last couple
            For i As Integer = (NumColumns - 1) To NumColumns - 4 Step -1
                ' size the column
                UltraWebGrid1.Columns(i).Width = Unit.Pixel(10)
            Next
        End Sub
