Hi I have a specific requirement that users may rearrange the order of the rows. We may need to provide up or down arrow for the selected row and if he clicks up arrow the row should move to one level above. i.e If I select row number 5 and click Up button the 5th row should move to 4th row and 4th row should become 5th row.
Or is there any way to drag and drop the rows in a desired place? i.e when I drag and drop a a row, it should be placed between the rows.
whichever is possible, please share your suggestions.
Arun.K.S
Hi Arun,
I was able to get row moving up/down going in the webgrid...I was using an up and down arrow buttons and just moving the selected row. THe suggested answer by Vince I believe is how to do it Server Side.
Anyway...here is a link to the post which had my code...otherwise I'll rip it out and send it to you if you like:
http://community.infragistics.com/forums/p/1211/85880.aspx#85880
Try this post:
http://community.infragistics.com/forums/p/26360/97006.aspx#97006
Let me know if this helps you.
Greetings
