20
Infragistics WebCombo
I have the licensed version of Infragistics v6.3 and one of my applications is using it.
Now in a new application, if i try to create a webcombo box without drag and drop from the box, rather by referencing the same dll.
But when i move from the source to the design page, the control does not appear and it says, "unable to locate license assembly".
And another doubt is that, does the control appear properly on a html page.?
Any suggestions here would be of great help.
Geetha
  • 155
    Suggested Answer
    It may occurs for the version conflict problem.If you install the 6.3 after you have install the hotfix of 6.3.
    Or have you set System restore? that also give the same type of problem.
    Kannan.S
