25
Enable/Disable checkboxes based on a condition for nodes
I want to enable some node checkboxes and disable checkboxes for some nodes depending on my business logic.
Could you provide me with a sample code to do this in Javascript?
  • 1923
    If you have access to the node(s) you wish to change (either through an event or some other node finding method)...perhaps try the following:
    // get access to the node
    var node = igtree_getNodeById(nodeId);
    // if the node was returned...
    if (node) {
          // disable node
          node.setEnabled(false);
          // enable node
          node.setEnabled(true);
