How do you move the legend to the top of the chart?
You have to set a custom control template for the chart.
If your chart is defined in c#, the easiest way to do this would be to create a control template in xaml and add it to the page resources, then assign it to the chart in code. Otherwise, you'll have to create the entire template in c#
<UserControl.Resources> <ControlTemplate TargetType="igChart:XamWebChart" x:Key="ChartTemplate"> <Border BorderBrush="{TemplateBinding BorderBrush}" BorderThickness="{TemplateBinding BorderThickness}"> <Grid x:Name="RootElement" Background="{TemplateBinding Background}" Margin="{TemplateBinding Padding}" > <Grid.RowDefinitions> <RowDefinition Height="Auto"/> <RowDefinition Height="Auto"/> <RowDefinition Height="*"/> </Grid.RowDefinitions> <Grid x:Name="CaptionPanel" Grid.Row="0"/> <Grid x:Name="LegendPanel" Grid.Row="1"/> <Grid x:Name="ScenePanel" Grid.Row="2"/> </Grid> </Border> </ControlTemplate></UserControl.Resources>
private void UserControl_Loaded(object sender, RoutedEventArgs e){ XamWebChart chart = new XamWebChart(); chart.Series.Add(new Series()); chart.Series[0].DataSource = new int[] { 1, 2, 3 }; ControlTemplate chartTemplate = this.Resources["ChartTemplate"] as ControlTemplate; if (chartTemplate != null) { chart.Template = chartTemplate; } LayoutRoot.Children.Add(chart);}
