How to create a dynamic(programatically) webgrid editable.
Hello , Goutam
Do you want to set the color in the row you have selected?
Is this what you mean ?
I understand that you want to set different color of each row by what you have said.
If you want this there is a way (the source code below is in the context of the snippet.txt)
editGrid
.setRowStyleClass("igGridRow"); // igGridRow is styleClass defines in igf_grid.css
editGrid.setRowAlternateStyleClass("igGridRowAlternate"); // igGridRowAlternate - styleClass
Keep in mind to define igGridRow and igGridRowAlternate in the igf_grid.css file inside the Theme
you are using :
.igGridRow
{background-color: #888888;}
.igGridRowAlternate
{background-color: #F5F5F5;}
I hope this helps!
Please let me know how can you retrieve the data from DATA_ROW and set the same in the following inside you java code:HtmlColumn firstNameColumn = new HtmlColumn ();firstNameColumn.setStyle("background-color: #AACC44;");
What i mean to say that the colour is set in the DATA_ROW object.During the creation of the table that should get pickedup and set in the column.How can it be possible to get the value from DATA_ROW in the java code?
The snipped is in the attached file.
Hi Gautam,
Here are some code snippets for you. The bolded text is about the background colour
I hope they will help you
public void initEditGrid() {
FacesContext context = FacesContext.getCurrentInstance();
clearGrid();
HtmlGridEditing gridEditing = new HtmlGridEditing();
Class[] args = new Class[] { CellValueChangeEvent.class };
UnifiedMethodExpression methodExpr = UnificationHelper
.createUnifiedMethodBLOCKED EXPRESSION;
Thanks Roshan. Yes it helped a lot.
Can you please let me know how to chnage the background colour of the column dynamically?
I used following code snipplet for doing the same:
Column basicColumn =
new Column();
basicColumn.setSortBy(
"basic" );
//Column Cell Style
UnifiedValueExpression uniValueExpressionColumnStyle = UnificationHelper.createUnifiedValueExpression(
basicColumn.setUnifiedValueBLOCKED EXPRESSION
But it didn't work.
Please provide me code snipplet for setting the coloum background colour dynamically.
