I'm new to Asp.Net and have only used Infragistic for Windows. So it is very possible that I'm not doing this correctly.
I have a WebDateChooser on my webpage. I did not set a default value because I want the field to appear empty.
There is no clientSideEvent code for the Initialization event handler. Here's my source for the webDateChooser:
igsch:WebDateChooser AllowNull="true" ID="DealStartDtChooser" Value= "" runat="server">
</igsch:WebDateChooser>
The webDateChooser displays "null" when the screen is rendered. Can someone tell me please what I need to do to have it display blank instead of "null"?
Thanks.
Lyric
The "NullDateLabel" is a property displayed in the properties of the WebDateChooser. Setting that to a blank string will do it. You don't have to start editing source.
Although a lot of forum replies give answers in terms of HTML source, as that is a generic answer, if you are using Visual Studio and have access to the smart tags it is generally better (i.e. less likely to cause errors/unexpected behaviour) to edit using those or make changes in the Properties window.
Hi,I normally just add:
NullDateLabel=" "
i.e. <igsch:WebDateChooser ID="ddlIncidentDate" runat="server" NullDateLabel=" "></igsch:WebDateChooser>This works for meRegardsMarc
