Hey Taz,
What do you propose I do in the second scenario?
" unless there is some kind of scripting issue causing the grid to not properly re-initialize itself back on the client after the update panel post back is completed. "
That's where I am at. Please advise.
Mark Hynes.
Hello Vic,
Can you post more details on the issue? Possibly the sample showing the problem. The grid should work fine when inside of an update panel, unless there is some kind of scripting issue causing the grid to not properly re-initialize itself back on the client after the update panel post back is completed.
Taz.
