The default paging mechanism is numeric-indeces for UltraWebGrid. How do you change the font color of the 'current page' indece to be different from the rest?
No, this is not right, I want the forecolor of the current index to be different than the rest of the indeces. For example, if the pager reads '1 2 3 4 5 6 7', AND if the current-ly selected index is 3, then the fore-color of the number 3 should be white, the other numbers should be a differenct color like blue or green or red. The point is that the current-ly selected index should be 'highlighted' via a different color. Do you know how to do this? I believe the past versions of the webgrid had this capability.
