40
UltraWebGrid.LoadPostData is terrible slow
I testing the performance of the UltraWebGrid in my test project using a profiler.
I'm using Infragistics2.WebUI.UltraWebGrid.v7.2, Version=7.2.20072.61
I'm working without viewstate and I'm binding my grid on every postback, I found that every postback the LoadPostBack method of the grid is called (even if I don't touch the grid on the client side).
It deserializes an encoded xml from the Request.From (in case that I didn't touch the grid you still have an xml there which contains an empty element).
Actually the thing that takes most of the time is serializer.GetXmlReader and not the deserialization itself.
I tried to remove the grids key from the Request.From (in case that it's an empty xml) and saw that performance increases. But it's a hack that can work only if the grid is not touched on the client side.
Is this a known issue? or I'm doing something wrong?
It there a way to overcome this perfformance issue?
