80
How to add DataKeyField programatically
I would like to inject the primary key column dynamically into a grid and set the DataKeyField to it.
If I pre define the primary key column in a UltraWebGrid and set the DataKeyField to it at design time,
and in UpdateCell event if I access e.Cell.Row.DataKey everything is working fine.
If I try to add the primary key column in a UltraWebGrid and set the DataKeyField to it programatically,
e.Cell.Row.DataKey returns null. Is there another way to achive this, I mean using some other lifecycle
events..?
<igtbl:UltraWebGrid ID="uwgDepositList" runat="server" Height="134px" Width="400px"
        OnInitializeRow="uwgDepositList_InitializeRow" OnUpdateCell="uwgDepositList_UpdateCell"
            <Bands>
                <igtbl:UltraGridBand BaseTableName="DepositItem" AllowUpdate="Yes">
                    <Columns>
                        <igtbl:UltraGridColumn BaseColumnName="GRID_KEY_ID" IsBound="True" Key="GRID_KEY_ID">
       <Header Caption="GRID_KEY_ID">
        <RowLayoutColumnInfo OriginX="1" />
       </Header>
       <Footer>
       </Footer>
      </igtbl:UltraGridColumn>
      <igtbl:UltraGridColumn BaseColumnName="COL_UNBOUND" IsBound="True" Key="COL_UNBOUND">
       <Header Caption="COL_UNBOUND">
       </Header>
       <Footer>
       </Footer>
                    </Columns>
                    <RowTemplateStyle BackColor="White" BorderColor="White" BorderStyle="Ridge">
                        <BorderDetails WidthBottom="3px" WidthLeft="3px" WidthRight="3px" WidthTop="3px" />
                    </RowTemplateStyle>
                    <AddNewRow View="NotSet" Visible="NotSet">
                    </AddNewRow>
                </igtbl:UltraGridBand>
            </Bands>
            <DisplayLayout BorderCollapseDefault="Separate" Name="uwgDepositList" RowHeightDefault="20px"
                StationaryMarginsOutlookGroupBy="True" TableLayout="Fixed" Version="4.00" AllowUpdateDefault="Yes"
                AutoGenerateColumns="False" CellClickActionDefault="Edit" RowSelectorsDefault="No">
                <FrameStyle BorderStyle="Solid" BorderWidth="1px" Font-Names="Verdana" Font-Size="8pt"
                    Height="134px" Width="400px">
                </FrameStyle>
                <RowAlternateStyleDefault BackColor="#FFFFC0">
                    <Padding Left="3px" />
                    <BorderDetails ColorLeft="255, 255, 192" ColorTop="255, 255, 192" />
                </RowAlternateStyleDefault>
                <EditCellStyleDefault BorderStyle="None" BorderWidth="0px">
                </EditCellStyleDefault>
                <FooterStyleDefault BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
                    <BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px" WidthTop="1px" />
                </FooterStyleDefault>
                <HeaderStyleDefault BackColor="LightGray" BorderStyle="Solid">
                </HeaderStyleDefault>
                <RowStyleDefault BorderColor="Gray" BorderStyle="Solid" BorderWidth="1px" Font-Names="Verdana"
                    Font-Size="8pt">
                    <BorderDetails ColorLeft="White" ColorTop="White" />
                </RowStyleDefault>
                <AddNewBox>
                    <BoxStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
                    </BoxStyle>
                </AddNewBox>
                <ActivationObject BorderColor="Black" BorderWidth="">
                </ActivationObject>
                <FilterOptionsDefault>
                    <FilterDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px"
                        CustomRules="overflow:auto;" Font-Names="Verdana,Arial,Helvetica,sans-serif"
                        Font-Size="11px" Width="200px">
                        <Padding Left="2px" />
                    </FilterDropDownStyle>
                    <FilterHighlightRowStyle BackColor="#151C55" ForeColor="White">
                    </FilterHighlightRowStyle>
                    <FilterOperandDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid"
                        BorderWidth="1px" CustomRules="overflow:auto;" Font-Names="Verdana,Arial,Helvetica,sans-serif"
                        Font-Size="11px">
                    </FilterOperandDropDownStyle>
                </FilterOptionsDefault>
            </DisplayLayout>
        </igtbl:UltraWebGrid>
private void Page_Load(object sender, EventArgs e)
      InitData();
public void InitData(UltraWebGrid grid)
            if (!IsPostBack)
                //grid.Columns.Add(new UltraGridColumn("SEL", "", ColumnType.CheckBox, false))
                DataTable oDt = new DataTable("DepositItem");
                oDt.Columns.Add(new DataColumn("ROW_KEY", typeof (int)));
                oDt.Columns.Add(new DataColumn("GRID_KEY_ID", typeof (String)));
                oDt.Columns.Add(new DataColumn("COL_UNBOUND", typeof (String)));
                var row = oDt.NewRow();
                row["ROW_KEY"] = 111;
                row["GRID_KEY_ID"] = "1000";
                row["COL_UNBOUND"] = "1000Test";
                oDt.Rows.Add(row);
                row = oDt.NewRow();
                row["ROW_KEY"] = 222;
                row["GRID_KEY_ID"] = "2000";
                row["COL_UNBOUND"] = "2000Test";
                oDt.Rows.Add(row);
                grid.DataSource = oDt;
                grid.DataBind();
 protected void uwgDepositList_UpdateCell(object sender, CellEventArgs e)
            int i = 0;
        protected void uwgDepositList_InitializeRow(object sender, RowEventArgs e)
