290
Group a Column By Default
I am using Netadvantage 6.3, with ASP.NET 2.0, Visual Studio 2005.  That said, I wouldl ike to have the UltraWebGrid, onLoad, default to a specified column for GroupBy.
Is this possible?  How.
Thanks.
MsBajanLady
  • 811
    Verified Answer
    MsBajanLady,
    You can achieve this by using the IsGroupByColumn property of the Column. Use the following code:
    In Visual Basic:
    Imports Infragistics.WebUI.UltraWebGrid
    ' Set the ViewType property to GroupBy mode
    Me.UltraWebGrid1.DisplayLayout.ViewType = ViewType.OutlookGroupBy
    ' Set the IsGroupByColumn property to True
    Me.UltraWebGrid1.DisplayLayout.Bands(0).Columns(0).IsGroupByColumn = True
    In C#:
    using Infragistics.WebUI.UltraWebGrid;
    //Set the ViewType property to GroupBy mode
    this.UltraWebGrid1.DisplayLayout.ViewType = ViewType.OutlookGroupBy;
    //Set the IsGroupByColumn property to true
    , Use column index
    this.UltraWebGrid1.DisplayLayout.Bands[0].Columns[0].IsGroupByColumn = true;
    Thank you.
    Bunty :)
