30
Additional parameters to WebCombo's client-side event handler
Has there been any development for the webcombo's client-side event handler to accpet additonal parameters?
I have a user control with a webcombo in it.  The selection of an item from the webcombo triggers an update to a target user control's webcombo value.  However, without having the ability to pass on a second parameter to the webcombo client-side event, I'm unable to specify my target webcombo to update.  There are a number of user controls that serve as potential target for updates.  They are loaded dynamically on run time -- hence I cannot hardcode the ID in to use igcmbo_getComboById(targetWebcomboControlID).  I would like to know how to get the targetWebcomboControlID from the dynamically loaded user controls into the webcombo's AfterSelectChange event if possible.  Currently the AfterSelectChange event takes the webcombo's ID only.)  Or, is there a way to name the ID for the webcombo when my user control is loaded, so that I can store the target control's ID as a part of the Webcombo ID and then parse the ID and find out what my target is?  There must be a better way, anyone?
VirtualCube
  • 155
    You can use the selectWhere property in client side javascript to add the additional filter condtion of the Webcombo.
    Example : webcombo.selectWhere("EmpNo='h123'");
    Kannan.S
