I have an UltraWebGrid bound to a DataTable that has two Columns in the Primary Key.In NetAdvantage 2009 Volumn 1, the events UpdateRowBatch and DeleteRowBatch are never fired. In previous versions, it worked correctly.
Can anyone help me?Thanks.
The provided description is a brief summary of the issue. I would like to know more details about the issue. I think you are not using AJAX, right? What other events are you handling? Can you please provide the details where it worked before including the software versions?
Sarita
I have installed the latest HotFix (NetAdvantage_ASPNET_20091_SR_2040.msp) and now it works fine!!!!
In the document "AspNET_EN_FixedBugs_SR09_4.pdf" is the following fixed bug: "When using composite primary key the UltraWebGrid doen not return selected row count as well as UpdateRow event does not trigger."
Thanks.
