hello... the event is never fire. Why?? I have to activate some properties??
<ignav:UltraWebTree ID="UltraWebTree1" runat="server" DefaultImage=""
HiliteClass="" HoverClass="" Indentation="20" AllowDrag="True"
OnNodeClicked="UltraWebTree1_NodeClicked">
U might check the selectable property is set to "True",
U can also check whether all autopostback flags are set to "True"
U can also try by declaring the event from pageload:
UltraWebTree1.NodeClicked += new Infragistics.WebUI.UltraWebNavigator.NodeClickedEventHandler(UltraWebTree1_NodeClicked);
HI,
I don't see how you are loading nodes into your tree. I tried to duplicate you issue, but could not.
Here is my aspx page: - my NodeClick event fires.
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="Default.aspx.cs" Inherits="_Default" %>
<%@ Register assembly="Infragistics2.WebUI.WebDataInput.v9.1, Version=9.1.20091.2015, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.WebDataInput" tagprefix="igtxt" %>
<%@ Register assembly="Infragistics2.WebUI.UltraWebNavigator.v8.1, Version=8.1.20081.2150, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebNavigator" tagprefix="ignav" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"><head runat="server"> <title>Untitled Page</title>
<script type="text/javascript" id="Infragistics"><!--
function WebNumericEdit1_TextChanged(oEdit, newText, oEvent){ //Add code to handle your event here. debugger;}// --></script></head><body> <form id="form1" runat="server"> <div> <igtxt:WebNumericEdit ID="WebNumericEdit1" runat="server" oncustombuttonpress="WebNumericEdit1_CustomButtonPress" onvaluechange="WebNumericEdit1_ValueChange"> <SpinButtons Display="OnRight" /> <ClientSideEvents TextChanged="WebNumericEdit1_TextChanged" /> </igtxt:WebNumericEdit> </div> <ignav:UltraWebTree ID="UltraWebTree1" runat="server" DefaultImage="" HiliteClass="" HoverClass="" Indentation="20" OnNodeClicked="UltraWebTree1_NodeClicked"> <Levels> <ignav:Level Index="0" /> </Levels> <Nodes> <ignav:Node Text="Root Node"> <Nodes> <ignav:Node Text="Child Node"> </ignav:Node> <ignav:Node Text="Child Node"> </ignav:Node> <ignav:Node Text="Child Node"> </ignav:Node> </Nodes> </ignav:Node> <ignav:Node Text="Root Node"> <Nodes> <ignav:Node Text="Child Node"> </ignav:Node> <ignav:Node Text="Child Node"> </ignav:Node> <ignav:Node Text="Child Node"> </ignav:Node> </Nodes> </ignav:Node> <ignav:Node Text="Root Node"> <Nodes> <ignav:Node Text="Child Node"> </ignav:Node> <ignav:Node Text="Child Node"> </ignav:Node> <ignav:Node Text="Child Node"> </ignav:Node> <ignav:Node Text="Child Node"> </ignav:Node> </Nodes> </ignav:Node> </Nodes> </ignav:UltraWebTree> </form></body></html>
my code-behind:
using System;using System.Configuration;using System.Data;using System.Web;using System.Web.Security;using System.Web.UI;using System.Web.UI.HtmlControls;using System.Web.UI.WebControls;using System.Web.UI.WebControls.WebParts;
public partial class _Default : System.Web.UI.Page { protected void Page_Load(object sender, EventArgs e) {
} protected void WebNumericEdit1_CustomButtonPress(object sender, EventArgs e) {
} protected void WebNumericEdit1_ValueChange(object sender, Infragistics.WebUI.WebDataInput.ValueChangeEventArgs e) {
} protected void UltraWebTree1_NodeClicked(object sender, Infragistics.WebUI.UltraWebNavigator.WebTreeNodeEventArgs e) {
