Infragistics web grid not work on IE 8.0.
When i select perticular row i found javascript errro display in above screen shot.
Error Message : Style.cssText is null or not an object.
So can any one suggest what i am missing to do in this control.
I have use NetAdvantage 2006 Volume 3 CLR 2.0.
So are there any resolutoin with Infragistics web grid not work on IE 8.0.
When i select perticular row i found javascript errro display in above screen shot ?
For us to buy 2009 is not an option
Can you reproduce this behavior in NetAdvantage for Web Client (ASP.NET) 2009 Volume 1? This is the version we're working to make compatible with Internet Explorer 8 (along with future releases).
If so, then you should certainly submit a support request so that Developer Support can investigate further.
