Dear All,
I am using IG 9 version in my asp.net application. My problem is under Opera browser the grid's functionality not working; particularly the pagination functionality and also this browser add one more column called "EditColumn" in the grid.
Webhtmleditor funcationality is also not working under Opera browser.
Can any one tell me the reason and also the solution for fix this problem.
Please reply as early as possible.
Thanks in advance,
Regards,Vasanth.
Unfortunately this browser was not targeted by most of the classic Infragistics controls. WebHtmlEditor also has problems with it.
Thanks for your reply, i will try with webdatagrid, also i want to know, the webhtmleditor funcationality is also not working under Opera browser. Please suggest me the solution for this.
Vasanth.
I'd suggest you to switch to the WebDataGrid, which was tested with and supports the Opera browser.
