25
How to bind WebTextEdit control to Access table column on Web form
I am new at Infragistics and have an MS Access background.  I want to bind a single WebTextEdit control on a Web form to a data column in an Access MDB table using an AccessdataSource.  I looked for  sample code/documentation and did not find anything.  Am new at this so I need a kind of beginner's type of assistance.  Any help is appreciated.
  • 25
    Tks.  Sample code was helpful.
  • 995
    Suggested Answer
    I assume, you want to bind single value from the Access database to the WebTextEdit control. You can use AccessDataSource to connect to the .mdb file and create connection string based on location of the Access database file. Using the “Configure Data Source” wizard, you can create SQL statement to retrieve data from the table.  When you have following simple Access table, you can use this code snippet to retrieve data from the location rowNumber X column “Name”  to bind to Text property of WebTextEdit. The rowNumber is hard coded.
    String conn = this.AccessDataSource1.ConnectionString;
            OleDbConnection connec = new OleDbConnection(conn);
            try
                int rowNumber = 0; to get Sarah’ name
                connec.Open();
                OleDbDataReader dr;
                OleDbCommand cmd = new OleDbCommand("SELECT * FROM Table1", connec);
                dr = cmd.ExecuteReader();
                while (dr.Read() && rowNumber == 0)
                    rowNumber++;
                    this.WebTextEdit1.Text = dr["Name"].ToString();
                         catch (Exception)
    I have used following acces table:
    Table1
    ID
    Name
    City
    1
    Sarah
    Berlin
    2
    John
    London
    3
    Sam
    Paris
