I am Using Ultraweb menu in MasterPage. One i Check in FF, I am Getting Error Like this
This Error shows in WebResources.asd.
Can any one fix... Please I need a Solution. Its very urgent.
when I had that problem with Firefox, the problem turned out to be adding the "/" at the beginning. I've also had FireFox get lost when I used a "\" instead of a "/".
this is what i given for target.
wbmnuProllenium.Items(1).Items.Add(
"Purchasing").TargetUrl =
"Purchase.aspx"
I am getting error in like this
Error: this.__igmenu_navigateUrl is not a functionSource File: http://localhost:49437/Prollenium/WebResource.axd?d=4mMGxFMoKHWaIhrm8vz-G_Tv2P2bc4lj0d5leGibn2eO5HpgSrpVGXoEZQ0oxAc7ioThg2s27PaE30ewgd3TrsBkHQ1kmYOckv5V8eZM0MmtUsYfrO3kGYQ8RyivAuonAPr7uwo1ueKzORUyF1nFOQ2&t=633323656740000000Line: 1430
I am using NetAdvantage 7.3 2007. I am using MasterPage & Content Page. In Master Page I am having UltraWebMenu(Target URL in Serverside). I am getting this error only in FireFox not in IE. Can any one please Help me.
Hello Sandara,
Could you provide which version/build of NetAdvantage for ASP.NET you are using? It would be also extremely helpful if you can provide a sample page which we can test against that error.
