I hope to have explain the problem.. can you help me please !!! :)
Thanks Andrea
In the NetAdvantage for JSF 2008 volume 1 release, the NetAdvantage for JSF components can perform AJAX operations within portal environments.
The documentation explains how to configure and deploy NetAdvantage for JSF components on to the JBoss Portal
http://help.infragistics.com/Help/NetAdvantage/JSF/2008.1/HTML/JSF_Getting_Started_JBoss_Portal.html
JBoss 2.4.* and 2.6.* are supported.
Andrea:
NetAdvantage definitely supports JBoss for portlets. In version 8.1, full support for AJAX in this and otherportal environments is supported as well. As Tim suggests, it'd be best for you to contact dev support for help.
Deployment to JBox Portal can be quite complex. I suggest contacting Developer Support by submitting an incident so they can try to work thru your issues.
