40
Problem with Hierarchical WebGrid
I have Hierarchical Webgrid with 4 Bands
First 2 bands I created from 2 tables when I added relathiomship it works
Then I created a new DataSet and add data to 3 band also is working but when I tied to add data from different RecordSet to 4 Band I all time received an error
Object reference not set to an instance of an object.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Line 177:	<tr ><td>
Line 178:
Line 179:	<igtbl:ultrawebgrid id="UltraWebGrid2" runat="server"  Visible="False" >
Can you help me
Below is my code:
Sub
BindGrid()
Dim MyCommand As  SqlDataAdapter
Dim MyCommand1 As  SqlDataAdapter
Dim MyCommand2 As  SqlDataAdapter
Dim ID As Integer
Dim DS As New  DataSet
Dim i, i1, i2 As Integer
Dim iMax As Integer
Dim jMax, jMax1 As Integer
Dim j, j1 As  Integer
Dim Phone As  String
Dim children As  RowsCollection
Dim children1 As  RowsCollection
Dim found As Integer
Dim strSql As String
Dim row As  UltraGridRow
Dim UID As String
Dim uwgRow As  UltraGridRow
ID = Request("ID")
If DropDownList1.SelectedValue.Length = 1 Then
TableName = "crec" & Dropdownlist2.SelectedValue & "0" & DropDownList1.SelectedValue
Else
TableName = "crec" & Dropdownlist2.SelectedValue & DropDownList1.SelectedValue
End If
str = "select a.uid,last_name,first_name,site_number from scanauto_inmlist_xref a,inmate b where a.uid=b.uid and inmlist_id=" & ID & " order by a.uid"
str1 = "select distinct phone,uid from " & TableName & " where uid in (select uid from scanauto_inmlist_xref where inmlist_id=" & ID & ") and xaction_type in (10,11) order by uid "
str2 = "select distinct a.uid,phone,last_name,first_name,site_number from " & TableName & " a,inmate b where a.uid=b.uid and xaction_type in (10,11) and phone in( select phone from " & TableName & " where uid in (select uid from scanauto_inmlist_xref where inmlist_id=" & ID & ") and xaction_type in (10,11)) and a.uid not in (select uid from scanauto_inmlist_xref where inmlist_id=" & ID & ") order by phone "
MyCommand = New  SqlDataAdapter(str, MyConnection)
MyCommand1 =
New  SqlDataAdapter(str1, MyConnection)
MyCommand2 =
New  SqlDataAdapter(str2, MyConnection)
MyCommand3 = New  SqlDataAdapter(str2, MyConnection)
MyCommand.Fill(batchDataSet1, "scanauto_inmlist_xref")
MyCommand1.Fill(batchDataSet1, "crec1")
MyCommand2.Fill(DS, "crec2")
batchDataSet1.Relations.Add("scanauto_inmlist_xref", batchDataSet1.Tables("scanauto_inmlist_xref").Columns("uid"), batchDataSet1.Tables("crec1").Columns("uid"))
Me.UltraWebGrid2.DataSource = batchDataSet1.Tables("scanauto_inmlist_xref").DefaultView
Me.UltraWebGrid2.DataBind()
UltraWebGrid2.DisplayLayout.Bands(1).Columns(1).Hidden =
True
UltraWebGrid2.DisplayLayout.ViewType = Infragistics.WebUI.UltraWebGrid.ViewType.Hierarchical
Dim Band As New  Infragistics.WebUI.UltraWebGrid.UltraGridBand
Dim Band1 As New  Infragistics.WebUI.UltraWebGrid.UltraGridBand
UltraWebGrid2.DisplayLayout.AutoGenerateColumns = False
UltraWebGrid2.DisplayLayout.AllowAddNewDefault = AllowAddNew.Yes
UltraWebGrid2.DisplayLayout.AllowUpdateDefault = AllowUpdate.Yes
UltraWebGrid2.Bands.Add(Band)
UltraWebGrid2.Bands(2).Columns.Add(0, "UID")
UltraWebGrid2.Bands(2).Columns.Add(1, "Phone")
UltraWebGrid2.Bands(2).Columns.Add(2, "Last Name")
UltraWebGrid2.Bands(2).Columns.Add(3, "First Name")
UltraWebGrid2.Bands(2).Columns.Add(4, "Site Number")
UltraWebGrid2.Bands(3).Columns.Add(0, "Phone")
UltraWebGrid2.Bands(3).Columns.Add(1, "Name")
UltraWebGrid2.Bands(3).Columns.Add(2, "Address")
UltraWebGrid2.DisplayLayout.Bands(3).AllowAdd = AllowAddNew.Yes
UltraWebGrid2.DisplayLayout.Bands(3).AllowUpdate = AllowUpdate.Yes
UltraWebGrid2.DisplayLayout.Bands(2).RowSelectors = RowSelectors.Yes
UltraWebGrid2.DisplayLayout.Bands(2).AllowAdd = AllowAddNew.Yes
UltraWebGrid2.DisplayLayout.Bands(2).AllowUpdate = AllowUpdate.Yes
UltraWebGrid2.DisplayLayout.Bands(3).RowSelectors = RowSelectors.Yes
iMax = UltraWebGrid2.Rows.Count
For i = 0 To  iMax - 1
If UltraWebGrid2.Rows(i).HasChildRows = True Then
children = UltraWebGrid2.Rows(i).Rows
jMax = children.Count
If jMax > 0  Then
For j = 0 To  jMax - 1
Phone = children(j).Cells(0).Text
found = 0
If DS.Tables(0).Rows.Count > 0  Then
Dim dr As  DataRow
For i1 = 0 To  DS.Tables(0).Rows.Count - 1
dr = DS.Tables(0).Rows(i1)
If Phone = dr("phone")  Then
found = 1
uwgRow =
New UltraGridRow(True)
uwgRow.Cells.Add(New  Infragistics.WebUI.UltraWebGrid.UltraGridCell)
uwgRow.Cells(0).Value = dr("uid")
uwgRow.Cells.Add(
uwgRow.Cells(1).Value = dr("phone")
uwgRow.Cells.Add(
uwgRow.Cells(2).Value = dr("last_name")
uwgRow.Cells.Add(
uwgRow.Cells(3).Value = dr("first_name")
uwgRow.Cells.Add(
uwgRow.Cells(4).Value = dr("site_number")
children(j).Rows.Add(uwgRow)
Else
If found = 1 Then
 Exit For
End If
Next
End If
Next
End If
End If
Next
UltraWebGrid2.DisplayLayout.Bands(2).Columns(1).Hidden = True
If jMax > 0  Then
If children(j).HasChildRows = True Then
children1 = children(j).Rows
jMax1 = children1.Count
If jMax1 > 0  Then
For j1 = 0 To  jMax1 - 1
UID = children1(j1).Cells(0).Text
Phone = children1(j1).Cells(1).Text
strSql = "select distinct phone,uid from " & TableName & " where xaction_type in (10,11) and uid<>0 and uid =" &
CInt(UID) & " and phone <>'" & Phone & "' order by phone "
MyCommand3 =
New  SqlDataAdapter(strSql, MyConnection)
Dim DS1 As New  DataSet
MyCommand3.Fill(DS1, "List")
Dim dr1 As  DataRow
If DS1.Tables(0).Rows.Count > 0 Then
For i2 = 0 To  DS1.Tables(0).Rows.Count - 1
dr1 = DS1.Tables(0).Rows(i2)
Dim uwgRow1 As UltraGridRow = New UltraGridRow(True)
uwgRow1.Cells.Add(
uwgRow1.Cells(0).Value = dr1("phone")
uwggRow1.Cells.Add(New Infragistics.WebUI.UltraWebGrid.UltraGridCell)
uwgRow1.Cells(1).Value = ""
uwgRow1.Cells.Add(
uwgRow1.Cells(2).Value = ""
children1(j1).Rows.Add(uwgRow1)
Next
End If
Next
End  If
End If
Next
End If
End If
Next
UltraWebGrid2.Visible = True
End Sub
