When doing document.form1.item("txtHPoints").value it doesn't work when the control is inside the UltraWebTab control. How can I reference the value of this INPUT control inside the UltraWebTab?
Here is my page...if you move the controls outside the UltraWebTab then the document.form1.item("txtHPoints").value works find.
<%@ Page Language="VB" AutoEventWireup="false" CodeFile="test3.aspx.vb" Inherits="testing_test3" %><%@ Register Assembly="Infragistics2.WebUI.UltraWebTab.v7.3, Version=7.3.20073.38, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.UltraWebTab" TagPrefix="igtab" %><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml" ><head runat="server"><title>Untitled Page</title><script language="javascript" type="text/javascript">function calcDollarAmount() { if (document.form1.item("txtHPoints").value != "") { document.form1.item("txtHDollars").value = "$" + CurrencyFormatted(parseFloat(document.form1.item("txtHPoints").value) / 100); } }function CurrencyFormatted(amount){ var i = parseFloat(amount); if(isNaN(i)) { i = 0.00; } var minus = ''; if(i < 0) { minus = '-'; } i = Math.abs(i); i = parseInt((i + .005) * 100); i = i / 100; s = new String(i); if(s.indexOf('.') < 0) { s += '.00'; } if(s.indexOf('.') == (s.length - 2)) { s += '0'; } s = minus + s; return s;}</script></head><body> <form id="form1" runat="server"> <div> <igtab:ultrawebtab id="UltraWebTab1" runat="server"><Tabs><igtab:Tab><ContentTemplate> Points<input id="txtHPoints" type="text" onchange="calcDollarAmount()" runat="server" /> <br /> Value<input id="txtHDollars" type="text" runat="server" /></ContentTemplate></igtab:Tab></Tabs></igtab:ultrawebtab> </div> </form></body></html>
ajgould,
Javascript is case-sensitive, and in your HTML the form's ID is "form1". Change the line that is erroring out to "document.form1.TransferID.value" and that should work.
~Kim~
Thank you for the reference, I followed Technique 2 and was unable to get the reference to the WebTextEdit control. Get 'document.Form1.TransferID' is null or not an object error after I type in some data into the WebTextEdit control.
Thank you for the help.
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load Dim TextEditorInsideTab As WebTextEdit TextEditorInsideTab = CType(UltraWebTab1.FindControl("WebTextEdit1"), WebTextEdit) TransferID.Value = TextEditorInsideTab.ClientID End Sub
<html xmlns="http://www.w3.org/1999/xhtml" ><head runat="server"><title>Untitled Page</title><script language="javascript" type="text/javascript">function calcDollarAmount() { alert(igedit_getById(document.Form1.TransferID.value)); }</script></head><body> <form id="form1" runat="server"> <igtab:ultrawebtab id="UltraWebTab1" runat="server"><Tabs><igtab:Tab> <ContentTemplate> <igtxt:WebTextEdit ID="WebTextEdit1" runat="server"> <ClientSideEvents ValueChange="calcDollarAmount" /> </igtxt:WebTextEdit> </ContentTemplate></igtab:Tab></Tabs></igtab:ultrawebtab><input type="hidden" runat="server" id="TransferID" /> </form></body></html>
The UltraWebTab control is a naming container, which means that any controls inside one will have their client-side IDs modified to prevent mutltiple controls from having the same clientID. There are a couple of ways to work around this; you can find more information here.
Hope this helps,
Looks like if my original ticket I failed to mention that I have nested UltraWebTabs and the controls are inside the child web tab control. If I had one UltraWebTab control, this does work, document.form1.item("UltraWebTab1_ctl00_txtHPoints").value.
How can I get to my control that inside nested UltraWebTab controls?
UltraWebTab1 = Parent
UltraWebTab2 = Child
txtHPoints is contained inside the UltraWebTab2 and is what I need to reference.
Hence, the UltraWebTab control is container control, objects inside WebTab have different client side Ids. You can use following client side Ids in your applictaion or use document.getElementById(id).
"UltraWebTab1_ctl00_txtHDollars"
