Please visit this link to our Knowlege Base article, which explains how to do it with step by step example:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.Aspx?ArticleID=9965
Hope this helps.
Sarita
It is UltraWebGrid.
Is it UltraWebGrid or WebDataGrid? Please specify.
I assume you want to make the changes to the Grid on the client side and capture all them on the server side at once. If so, then you can handle the UpdateRowBatch event or UpdateCellBatch event on the serverside. Thus when the customer makes the changes on the client side and clicks a save button, which triggers a postback, the UpdateRowBatch or UpdateCellBatch event gets fired for every row/cell changed in the Grid.
Please visit the following link to learn more about this:
http://help.infragistics.com/Help/NetAdvantage/NET/2008.3/CLR3.5/html/Infragistics35.WebUI.UltraWebGrid.v8.3~Infragistics.WebUI.UltraWebGrid.UltraWebGrid~UpdateRowBatch_EV.html
http://help.infragistics.com/Help/NetAdvantage/NET/2008.3/CLR3.5/html/Infragistics35.WebUI.UltraWebGrid.v8.3~Infragistics.WebUI.UltraWebGrid.UltraWebGrid~UpdateCell_EV.html
