I'm using the WebCurrencyEdit control to enter dollar amounts but now need to change them to enter whole dollar amounts only. The behavior I'd like is that if the user enters an amount with decimals, it gets rounded off to the nearest whole dollar as they leave the field. I've tried setting the DataMode to Long which prevents any decimal places by ignoring the decimal point. But I'm concerned with a user entering "123.45" and getting "12,345". I've also tried setting MinDecimalPlaces to None and manually rounding the value as I read it from the control. This worked better but it seems the control should be able to handle this. I've read other posts here that mention the Culture property but I'm not clear how to use that after looking at the forums, documentation and sample apps. If that is the answer could someone post a simple example?
Thanks.
HI,
Wire up the WebCurrencyEdiors Client-Side ValueChange event
Here a code snippet to do what you want
function WebCurrencyEdit1_ValueChange(oEdit, oldValue, oEvent){ //Add code to handle your event here. var val = oEdit.getValue(); val = Math.ceil(val); oEdit.setValue(val); }
