475
UltraWebMenu_ItemClick not always executing CallServer in Firefox
Hi!
I have a UltraWebMenu on a Master Page and I have the ClientSideEvent UltraWebMenu_ItemClick registered.  In the ItemClick I call the server using a ClientCallBack approach i.e. CallServer(parameter) and on the server side in the RaiseCallbackEvent method various things are performed that are needed for my page to work correctly.
My problem is that in Firefox the ItemClick event for the UltraWebMenu is executed but it does NOT always execute the CallServer command but it always works in IE 7.  The strange thing is that if I insert alert("test"); after the CallServer command in the ItemClick event it seems to always work in Firefox as well.
Is there a bug with ClientSideEvents for UltraWebMenu in Firefox or am I doing something wrong?
Here is the ClientSide Event for the UltraWebMenu ItemClick:
function UltraWebMenu1_ItemClick(menuId, itemId)
   CallServer('1' + ';' + itemId, '');
Here is the UltraWebMenu definition in the MasterPage:
<ignav:UltraWebMenu ID="UltraWebMenu1" runat="server" DisabledClass="" FileUrl=""
                            Font-Bold="True" ForeColor="White" ItemSpacingTop="2" JavaScriptFilename="" JavaScriptFileNameCommon=""
                            LeafItemImageUrl="" ParentItemImageUrl="" SeparatorClass="" StyleSetName="" TargetFrame=""
                            TargetUrl="" TopItemSpacing="Compact" TopSelectedClass="" Width="100%" BorderCollapse="True"
                            ItemSpacingSubMenus="2" BorderStyle="None" Style="float: left; position: relative;
                            top: 57px; font-size: x-large; font-weight: bolder;" HideDropDowns="False">
                            <IslandStyle BorderStyle="Outset" BorderWidth="1px" Cursor="Default" Font-Names="MS S***rif"
                                Font-Size="8pt" ForeColor="Black">
                            </IslandStyle>
                            <TopSelectedStyle CssClass="menuButtonSelected">
                                <BorderDetails WidthBottom="1px" WidthLeft="1px" WidthRight="1px" WidthTop="1px" />
                            </TopSelectedStyle>
                            <HoverItemStyle Cursor="Default" Font-Overline="False" ForeColor="White">
                                <Margin Bottom="0px" Left="0px" Right="6px" Top="0px" />
                                <Padding Bottom="0px" Left="0px" Right="0px" Top="0px" />
                            </HoverItemStyle>
                            <ItemStyle Font-Bold="False" Font-Names="Arial" Font-Size="9pt">
                                <Margin Right="6px" />
                            </ItemStyle>
                            <DisabledStyle BorderStyle="Solid" ForeColor="LightGray">
                            </DisabledStyle>
                            <Levels>
                                <ignav:Level Index="0" />
                            </Levels>
                            <ExpandEffects ShadowColor="LightGray"></ExpandEffects>
                            <MenuClientSideEvents ItemClick="UltraWebMenu1_ItemClick" />
                        </ignav:UltraWebMenu>
I sincerely hope there is a solution to this!!!
