100
Webgrid Using webcombo`s
hi
I have a ultrawebgrid and and on each row I have 5 webcombos placed into the 5 of the Cells which works perfectly.  Each webcombo consists of 2 columns an ID, Description and is bound by a Datatable whicd I create and fill  in code.  I have set the datatextfield to equal the description so it displays the Text in the webgrid cell when a webcombo option is selected and the datavaluefield to be the ID but when ever i run the AddNewRow which is done on click on a button in the aspx page and runs the AddnewRow on server side which works fine, this causes a postback, but on postback all the cells which were webcombos now display the ID and not the Text field and i want the text value displayed not the ID anybody any ideas how i can do this.  My ultrawebgrid is a user control dropped into an ASPX page and the AddNewRow button is not on the user control but on the parent aspx page if this helps.  I must save the values as the ID though but want to display the text value to user not the ID.
thanks
