I have a webmenu that WebMenuTarget="PopupMenu" . When i right-click on a node, i am able to see the menu in IE but not in Firefox.. Here is the code
function
UltraWebTree1_NodeClick(treeId, nodeId, button)
alert(text);
igmenu_showMenu(
'UltraWebMenu1',null);
I am using Infragistice NetAdvantage 2008 Vol 3.5. I am usinf Firefox 3.0 version. Can someone help me out?
Raja.
You are right, I reproduced your issue and found same behavior. You can submit this issue at following link:http://devcenter.infragistics.com/Protected/SubmitSupportIssue.aspx
