Hi to all
i am using ultra web grid 8.3 with VS2008.see my screen shot.In IE 7.0 ultra web grid last column's right side border did not display.but it is working properly in mozilla .plz help me
Here's a workaround that may work for you:
http://codecorner.galanter.net/2010/08/03/ultrawebgrid-does-not-display-right-border/
I have the same problem with 20081.2161 in IE8, when hidden columns are present in the grid. The last column's right border is displayed correctly when turning off compatibility view in IE.
Some tips would be appreciated!
Oscar
Have you tested this behavior after installing the latest HotFix? If not, then please do so and let us know the results. To download the HotFIx, please visit www.Infragistics.com and then click on MyIG tab and login. If you have registered your keys then click on NetAdvantage tab. This will show all the keys registered under your profile. Select the key for 2008 Vol 3 and scroll down and find the HotFix section. Now please click on the desired HotFix link to download. The download should start immediately. The HotFix build number is 20083.2059.
If you have not registered your keys then after logging to the website, hover on Support tab and click on Register Your Product and register the keys. After this you will be able to see the keys under NetAdvantage tab located in MyIG.
Hope this helps.
