Infragistics2.WebUI.UltraWebGrid.ExcelExport.v6.3, Version=6.3.20063.1091
Private
Sub cmdExcel_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles cmdExcel.Click
Try
UltraWebGridExcelExporter1.Export(gridAssignments)
Catch ex As NullReferenceException
End Try
End Sub
Stepping through the code I always receive an exception (NullReferenceException) {"Object variable or With block variable not set."}, and the grid contains 8 rows. This error occurs at the line of execution and does not even fall into the catch. I have checked all related articles for this issue and have not found the answer. Any help would be great and thank you for your comments...
