504
ContextMenu does not open on any control when ASPX page is under Master page
I am getting this weired error everytime when i try to get the context menu open.
Here is my Scenario
1. Usercontrol with Menu and Webtree
2. User Control in a Page which is under Master Page
3. Menu has following Client and ASPX code
//Global Variable to store the menu name
var menuInstance;
function initMenu(menuId)
menuInstance = igmenu_getMenuById(menuId);
<ignav:UltraWebMenu...
MenuClientSideEvents InitializeMenu="initMenu"......./>
="initMenu"
</<ignav:UltraWebMenu>
Tree has following code
function ubtDataTree_NodeClick(treeId, nodeId, button)
//Context Menu Clik
if(button == 2)
var tree = igtree_getTreeById(treeId);
igmenu_showMenu(menuInstance, tree.event);
 <ignav:UltraWebTree....>
ClientSideEvents NodeClick="ubtDataTree_NodeClick"/>
</ignav:UltraWebTree>
Now i even tried with <%=UltrawebMenu1.ClientID %>
What could be th error?
  • 28407
    HI,
      I go the menu_id from the contextmenu's init event. I stored it in a javascrpt global variable.
    Here is my user control - UltraWebMenu2 is my context menu. - I tested it and it  worked.
    <%@ Control Language="C#" AutoEventWireup="true" CodeFile="WebUserControl.ascx.cs" Inherits="WebUserControl" %>
    <%@ Register assembly="Infragistics2.WebUI.UltraWebNavigator.v8.3, Version=8.3.20083.1009, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebNavigator" tagprefix="ignav" %>
    <script type="text/javascript" id="igClientScript">
    function UltraWebTree1_NodeClick(treeId, nodeId, button){
     //Add code to handle your event here.
    // var menu2 = <%= UltraWebMenu2.ClientID%>
    //debugger;
    // igmenu_showMenu(<%= UltraWebMenu2.ClientID.Replace("_","")%>)
       igmenu_showMenu(menu2);
    function UltraWebTree1_InitializeTree(treeId){
    var menu2 = null;
    function UltraWebMenu2_InitializeMenu(menuId){
      menu2 = menuId;
    </script>
    <ignav:UltraWebMenu ID="UltraWebMenu1" runat="server" JavaScriptFilename=""
        JavaScriptFileNameCommon="">
        <IslandStyle BackColor="LightGray" BorderStyle="Outset" BorderWidth="1px"
            Cursor="Default">
        </IslandStyle>
        <HoverItemStyle BackColor="DarkBlue" Cursor="Default" ForeColor="White">
        </HoverItemStyle>
        <Images>
            <SubMenuImage Url="ig_menuTri.gif" />
        </Images>
        <ItemStyle Cursor="Default" />
        <Items>
            <ignav:Item Text="Top Item">
                <Items>
                    <ignav:Item Text="Sub Menu Item">
                    </ignav:Item>
                    </ignav:Item>
                    </ignav:Item>
                    </ignav:Item>
                </Items>
            </ignav:Item>
                <Items>
                    </ignav:Item>
                    </ignav:Item>
                    </ignav:Item>
                </Items>
            </ignav:Item>
                <Items>
                    </ignav:Item>
                    </ignav:Item>
                </Items>
            </ignav:Item>
        </Items>
        <DisabledStyle Font-Names="MS Sans Serif" Font-Size="8pt" ForeColor="Gray">
        </DisabledStyle>
        <Levels>
            <ignav:Level Index="0" />
        </Levels>
        <SeparatorStyle BackgroundImage="ig_menuSep.gif" CssClass="SeparatorClass"
            CustomRules="background-repeat:repeat-x; " />
    <ExpandEffects ShadowColor="LightGray"></ExpandEffects>
    <MenuClientSideEvents InitializeMenu="" ItemChecked="" ItemClick="" SubMenuDisplay="" ItemHover=""></MenuClientSideEvents>
    </ignav:UltraWebMenu>
    <ignav:UltraWebTree ID="UltraWebTree1" runat="server" DefaultImage=""
        HiliteClass="" HoverClass="" Indentation="20" >
        <ClientSideEvents NodeClick="UltraWebTree1_NodeClick"
            InitializeTree="UltraWebTree1_InitializeTree" />
        <Levels>
        </Levels>
        <Nodes>
            <ignav:Node Text="Root Node">
                <Nodes>
                    <ignav:Node Text="Child Node">
                    </ignav:Node>
                    </ignav:Node>
                    </ignav:Node>
                    </ignav:Node>
                </Nodes>
            </ignav:Node>
                <Nodes>
                    </ignav:Node>
                    </ignav:Node>
                    </ignav:Node>
                    </ignav:Node>
                </Nodes>
            </ignav:Node>
                <Nodes>
                    </ignav:Node>
                    </ignav:Node>
                    </ignav:Node>
                </Nodes>
            </ignav:Node>
        </Nodes>
    <ignav:UltraWebMenu ID="UltraWebMenu2" runat="server" JavaScriptFilename=""
        JavaScriptFileNameCommon="" WebMenuTarget="PopupMenu" TargetFrame=""
        TargetUrl="">
            Cursor="Default">
        </IslandStyle>
        </HoverItemStyle>
        <Images>
        </Images>
        <Items>
            </ignav:Item>
            </ignav:Item>
            </ignav:Item>
            </ignav:Item>
            </ignav:Item>
        </Items>
        </DisabledStyle>
        <Levels>
        </Levels>
    <MenuClientSideEvents InitializeMenu="UltraWebMenu2_InitializeMenu" ItemChecked=""
