60
Grid-embedded WebDateChooser shows briefly in page before before Grid is rendered
Hi I have a WebDateChooser (WDC) embedded in a UltraGridCell in a WebForms page.  When the page is rendering, I see the WDC pop up for a second kind of under the left side of the Grid and then disappear.  After that, everything works fine with using the control from inside the Grid.  I think this a timing issue.  I've tried a few different ways of fiddling in JS with the Visible property of the WDC.  No luck yet.  Wondering if someone can help me.  Here's the code.
 Here's the Column Def:
 <igtbl:UltraGridColumn BaseColumnName="RequestedDate" DataType="System.DateTime" Hidden="False" Type="Custom" EditorControlID="WebDateChooser1" AllowUpdate ="Yes" IsBound="True" Key="RequestedDate">
           <Header Caption="Requested Date">
                <RowLayoutColumnInfo OriginX="4" />
           </Header>
           <Footer>
            </Footer>
</igtbl:UltraGridColumn>
Here's the WDC Def:
 <igsch:WebDateChooser id="WebDateChooser1" runat="server" Width="200px" Height="150px" Font Size="8pt" Visible="True" NullDateLabel="" Text="Null" Font-Names="Verdana" ShowDropDown="True">
     <EditStyle Font-Size="8pt" Font-Names="Verdana"></EditStyle>
     <ClientSideEvents EditKeyDown="WebDateChooser1_EditKeyDown" />
     <CalendarLayout DayNameFormat="FirstLetter" FooterFormat="" ShowNextPrevMonth="False" VisibleMonth="2009-01-01" ShowTitle="False" ShowFooter="False">
         <DayStyle Font-Size="9pt" Font-Names="Arial" BackColor="White"></DayStyle>
          <SelectedDayStyle ForeColor="Black" BackColor="Silver"></SelectedDayStyle>
          <CalendarStyle Font-Size="8pt" Font-Names="Verdana"></CalendarStyle>
          <DayHeaderStyle ForeColor="#A2A1A1" BackColor="White"></DayHeaderStyle>
          <TitleStyle BackColor="White"></TitleStyle>
      </CalendarLayout>
     <DropDownStyle Font-Size="8pt" Font-Names="Verdana"></DropDownStyle>
</igsch:WebDateChooser>
Thank you for your help..
Best,
Joel
