20
A valid key is required!
Hi, Gentlemen/women!
      We are in lookout to use Infragistics-netadvantage product in our project. Not only that, we also have a key to get this product installed. I deployed the contents into weblogic server, but for every operation i do, a window pops up referring to the need for a valid key.
I can't say whether the key is expired, or not. i tried by copying the license.txt file inside the WEB-INF directory, but that wasn't good enough.
Would you be interested in guiding me to get away with this key issue? Do write to me at my e-mail krishna.mohapatra@gmail.com at the earliest.
Krishna
Cell - 9739493252
  • 2301
    Suggested Answer
    Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
    Hi:
    So if you want to upgrade a license file here’s what you do.
    1.       Take the existing file and open it in a text editor. It’ll look something like this:
    NetAdvantage for JSF Vol1 2008,m211E47E013B7-46132113,123456789012345678
    2.       Remove the last 18 digits (everything after the last comma) and replace them with your new key
    3.       Your key will have two dashes in it: its total length is 20 characters remove the two dashes. The total length of the key will now be 18 digits.
    4.       Save the file and you’re done.
    To create a new file simply repeat the procedure above, but use a new, empty file and past the sample code above into it. After that replace the key as described in steps 2-4.
