Does anyone know if it is possible for a Row Edit Template user control to mimmick the "Greyed out" behavior of the area behind a WebDialogWindow?
R
The easiest way to get started is to examine the css resources that get shipped with the DialogWindow in the /ig_res folder - this way you will be able to use them as a starting point. You can edit pretty much everything in the RowEditTemplate, so you have good control on that.
