300
Context menu with a submenu
Hi, I am using UltraWebMenu as a context menu with a submenu.
The menu is shown when the user right clicks a web tree. When the tree is fully expanded a vertical scrollbal is used in explorer to view it's contents as it's height exceeds the screen's height. The problem is with the sub menu of the context menu.
If i scroll down the page, the context menu is shown as expected but the sub menu is not positioned correctly. In particular it is misplaced proportionally to the scrolling height and closer to the top of the screen.
If the page is not scrolled down everything works as expected.
Any suggestions?
  • 5118
     That sounds like an issue that existed for a time but we fixed in a hotfix for all affected versions.  Snag the latest public hotfix for the version you are on and all should be well.
