Dear sir:
I have asp.net page with a ultragrid with band 0 and band 1 . it work fine for data display. the band 1 is used load on demand = manual. i tried to export the grid to the excel with ultrawebgridexcelexporter control to export the data to excel but the band 1 is missing..... is there any way or sample to export both band0 and band 1?
best regards
From Edmond LUI
bobbo601,
Are you using the latest service release of NetAdavntage for .NET 2007 Volume 3? If not, I suggest that you download it from the My Keys and Downloads page and test your issue using the service release. This version is no longer actively maintained, so there are no new bug fixes being released for this version.
If the issue still occurs there, I recommend next that you test using our latest version, NetAdvantage for .NET 2009 Volume 1. You can use a trial version if you don't already have a key for it.
If the issue can still be reproduced in our latest release version, can you reproduce this behavior in a sample project that we can run and debug? If so, then please submit a support request and attach your sample, so that a Developer Support Engineer can investigate.
got exactly the same problem.
two bands, all expanded (ExpandAll(true), an ExcelExporter, but no second-level band is exported. I don't use demandLoad and all row are filled on databind
I'm using infragistics 7.3.
This isn't the behavior I'd expect. Your situation requires more in-depth research than we can provide over the forums, so I suggest we get this over to Developer Support.
Can you reproduce this behavior in an isolated sample project that we can run and debug? If so, then you can either submit a support request directly, attachng your project to the request and mentioning a link to this forum thread, or you can post the project here and I'll pass this over to Developer Support to have a case created. Submitting the support request directly will help us to get you a response more quickly.
Thks for you kindly reply:
I did expand the sub band by UI but the exported excell is not show the sub band.....so is there any more reference so i can try or follow?
edl0022 said:even i expand the sub band
If you expanded the parent row using the UI on the browser, then I don't believe the result you're seeing should be expected. If you confirm that this is what you're doing, I'll pass this to Developer Support for further research.
If you expanded the parent row programmatically on the server, then this is an expected result. Expanding a parent row programmatically on the server does not cause the DemandLoad event to be raised or for child rows to be populated. The programmer would need to manually populate the child rows explicitly in this case. My suggestion in this case is to bind to a data source that contains all the data at all levels, rather than data that is "optimized" for manual load-on-demand usage.
