Can you add nodes programatically to a tree as well as bind other levels at the same time? For example, the first level is a straightforward query that can be bound to the tree, but the second level has to be calculated based on first level nodes, and an intermediate dataset, so there is 2 relationships in between the first and second level nodes of the tree, and the third and fourth levels have only one relationship in between them both.
Thanks.
I've used this concept many times for both the WebMenu and the WebTree...
I have a single dataset where each row is a menu item or node item...the dataset has a Parent_ID field which has the ID of the parent...the topmost (root) node/items have a parent_id of NULL...
Then, to create the structure, simply iterate through the dataset...hopefully the following code makes sense...
1. Create a variable at the top of the class...something like this: (i have a strongly typed dataset called dsMenu with a MENU table in it). E.g:
Private _dsMenu As dsMenu
2. Add this code to the Page_Load event to begin adding the items to the control
' retrieve the data to build the menu_dsMenu = ...fill your dataset however you want...
' get all the top level nodes by selecting where parent_id is null...e.g. no parents!Dim drTopLevel() As dsMenu.MENURow = _dsMenu.MENU.Select("PARENT_ID IS NULL", "SORT_ORDER ASC")
' Call the MenuItemAddLoop function to add all the top level nodes...MenuItemAddLoop(drTopLevel)
3. Use this function to loop through a collection of rows...
Private Sub MenuItemAddLoop(ByVal Children() As dsMenu.MENURow) For Each Row As dsMenu.MENURow In Children ' Add the row to the tree MenuItemAdd(Row) ' find children of the current row... ' this is where the parent_id is the ' row's id... Dim Search As String = String.Format("PARENT_ID = {0}", Row.ID) Dim childNodes() As dsMenu.MENURow = _dsMenu.MENU.Select(Search, "SORT_ORDER ASC") ' if this menu item has children, run the loop ' for this item as well! If childNodes.Length > 0 Then MenuItemAddLoop(childNodes) Next End Sub
4. Use this function to add the new node to the control...this is just a single place to set up each menu item/node...the dataset row has all the data needed for each menu item...
Protected Sub MenuItemAdd(ByVal drMenuItem As dsMenu.MENURow) Dim lastNode As Item = Nothing Dim parentNode As Item = Nothing ' create a new menu item lastNode = New Item() ' set the text for the node lastNode.Text = drMenuItem.DESCRIPTION ' set the nodes tag. the tag must be ' unique. it is the PK of the table ' and this will make finding ' other nodes very easy! lastNode.DataKey = drMenuItem.ID lastNode.Tag = drMenuItem.ID ' check whether this is a root level menu item If drMenuItem.IsPARENT_IDNull Then ' nodes parent is null...add it directly ' to the tree so as to be a root level ' node... UltraWebMenu1.Items.Add(lastNode) Else ' node has a parent. find the parent ' in the tree using the PK/tag and ' then add it to the parents nodes ' collection (its children) parentNode = uwm_main.Find(drMenuItem.PARENT_ID) parentNode.Items.Add(lastNode) End If End Sub
i can explain more if necessary!
Hello Mr. Stankov,
I have a simlar situation and wanted to ask a question about option 2.
I already have the program structure to add the table to my dataset of items that creates the table for the tree structure's top level nodes. Of course, now the items now the tree must support items under the items.
Would I add an additional table to the dataset for the "sub-Items" and create a relation based on unique column id's, or would I be able to just have the two tables and add corresponding unique linking column id's for the "sub-items" and add another relation for the "sub-items"?
Data Binding as a operation generally in .NET clears all contents of the databound control. There are two options you can try:
1) First Data Bind the control and then add items programmatically
2) Change the datasource so that you first add items programmatically to the datasource itself, then bind the combines datasource to the tree.
Hope this helps.
