I am using the ultrawebgrid and using the Outlook group by for grouping the records.
I have n number of groups and each group can have n number of records.
In my grid i implemented the paging logic and I display only 10 records per page.
Also I use the following 2 lines for expanding the column while the page is loaded first time.
Grid.DataBind();
Grid.PerformGroupRows();
Grid.ExpandAll();
I am having the recordset which has the 2,3,4,5,6...etc page datas.
I have done that logic in this event LinkagesGrid_PageIndexChanged and when the above line is executed in perform group rows, my page breaks. I am pasting the error for your reference
System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values. Parameter name: index at System.Web.UI.ControlCollection.get_Item(Int32 index) at System.Web.UI.ControlCollection.RemoveAt(Int32 index) at Infragistics.WebUI.UltraWebGrid.RowsCollection.Sort() at Infragistics.WebUI.UltraWebGrid.UltraWebGrid.SortGroupRows(RowsCollection rows) at Infragistics.WebUI.UltraWebGrid.UltraWebGrid.PerformGroupRows() at UserControls_ViewLinkages.LoadData()
Can any one please help? I need the filtering, paging and sorting for the same. can any one please help? its urgent. I am stuck with this.
Thanks for your help.
S Nagarajan
