660
Loadondemand property
Also, I'm wondering about the loadondemand property.  If it is automatic, the documentation says that it will load data when the page loads.  Then, if that is the case, why even use it?  I thought the whole point was to only load data when a node is expanded and there are child nodes below it.  It also says that manual will only load when user expands a node, so shouldn't it be true or false then?  Unless, the documentation is missing something important?
