2167
Row edit template problems
I have an Ajax grid with Add New enabled.  When I click the "Add New" button it pops open the row edit template and this is fine if there are only maybe 5 records in the grid.  If there are more records in the grid than 1 section of the RowsRange property then inserting of the new row via the "Add New Box" causes a postback preventing the row edit template to show.
What can I do here?
Parents
No Data
Reply
  • 2167
    Verified Answer
    Not sure is this is the best method but I set a variable in:
    function UltraWebGrid1_AfterRowInsertHandler() {
    bNewRecord=false;
    Then cancel the template close event
    function UltraWebGrid1_BeforeRowTemplateCloseHandler(gridName, rowId, bSaveChanges){
    if (bNewRecord==true) {
    bNewRecord=false;
    return true;
    Seems to do the job... for now.
Children
No Data
