Has anyone else seen the problem where the scrollbar does not initially appear for someone using IE 7. I am running IE 8 under 7.0 compatibility and the scrollbar shows fine. It is not showing for the user until they highlight a cell in the last column and navigate up and down using the arrow keys. Then the scrollbar eventually appears. Quirky stuff. Just wondering if anyone else has run into it and solved this.
I have personally not encountered that. IE8 is still in beta, but if you encounter that for IE7 I think you can report that directly to developer support through our official channels here:
http://es.infragistics.com/Support/default.aspx#Overview
