There are a way to disable all the javascript events of the grid?
I want that the grid in the print preview page has no javascript event... i am having problems with this because the print preview page is throwing a javascript error when i move the mouse over the grid
onmousemove='igtbl_cellMouseMove(event,"wpmxwp986637087xTabControlxxctl2xGridControl");
Setting the grid to the read-only modes will remove varying degrees of javascript from the grid. Setting one of these modes should not create a javascript error, and you shouldn't have to manually remove the events. Check to see if there's a hotfix available for the version you're using, as this may have been a bug that has already been fixed. You can also contact Developer support through one of the options at www.infragistics.com/gethelp.
Hope this helps,
-Tony
