I found a javascript function, selectWhere(), in Infragistics help. I want filter the factory that user can choose according to their user id.
function dgdResult_AfterEnterEditModeHandler(gridName, cellId){ var cell = igtbl_getCellById(cellId); if (cell.Column.Key == "FACTORY_NAME") { var comboName = "cboFactory"; var combo = igcmbo_getComboById(comboName); if (combo) { var cell_user_id = cell.Row.getCellFromKey("USER_ID"); if (cell_user_id) { combo.selectWhere("COUNTRY_CODE IN (select country_code from user_country where user_id = '" + cell_user_id.getValue() + "')"); } } } }
But I found that it has no effect. In selectWhere(), I can only use simple condition like selectWhere("COUNTRY_CODE IN ('HK', 'JP')")
Is it the restriction of this function or did I do something wrong in the code?
My infragistics version is 6.2.20062.34 and I opened load-on-demand in webcombo.
The selectWhere() functionality of WebCombo applies a filter to an underlying DataView, not through a separate SQL call. I don't believe it's possible to write a multiple-condition statement except in your "simple condidtion" example.
