280
Style overriding on LoadPreset in Async Panel
Does anyone know what order the styles have to be in an xml file for the RowStyleDefault not to override the FixedheaderStyle when doing a datagrid.loadpreset(xmlfile.xml) ? Currently I have an ultrawebgrid in an Async panel, when I load the preset xml file everything is fine except that the RowStyleDefault  CSSClass I have defined is overriding the header style defined in the xml class. When the grid is taken out of the Async panel, all is right with the world. This must have to do with that whole CSS cascading hierarchy stuff. I've swtich the Rowstyledefault to be above the header styles in the xml file, hoping it would set the default style first then override it with the headers. No luck.
 I want to use the grid in an updatepanel, or async panel I'm not looking to use the async postback xml stuff built into the webgrid. Thanks!
