Version 2007.3
Currently I have an ultrawebgrid inside an asp.net(2.0 framework) updatepanel. When I first fill the grid everything looks fine. The grid has multilple
Headings(see below) with the correcly assigned css classes . When I sort the information , the sort works fine, but the very first main heading("WeekDays") loses its style class and turns
white with black text. Whats weird is that only the "Weekdays" main heading loses its style, the "Months" heading retains all the CSS qualities assigned
to it. After some brief playing around and adding a new main Heading called "Test" over just the "Mon" column and moving the "WeekDays" heading to be
only above Tues-Wed, the style was only lost for the "Test" main heading that is over the very first column when sorting. What would cause this?
Sample:
WeekDays Loses style on this one
(H1) WeekDays Months
(H2)Mon Tues Wed Jan Feb March
Data Data Data Data Data Data
Sample 2: Only the "Test" heading loses style on sorting for this one
(H1)Test WeekDays Months
Perhaps I can spare someone else several hours of anguish by putting in the fix.
All I had to do was change the columheader add to an insert
.Columns.Band.HeaderLayout.Insert(0, WeekdayColumn)
instead of
.Columns.Band.HeaderLayout.Add(WeekdayColumn)
Of course now I have it in an async panel loading styles from an xml file and the RowStyleDefault style is overriding the FixedHeaderRowStyle,
If I take it out of an async panel it works fine. The fun just keeps on comin'.
