I have an ultrawebgrid in an updatepanel that contains layered headers. For example I have
Dressings Croutons
Blue Cheese Ranch French Seasoned Unseasoned
The intial data load and display is exactly how I want it, however, when I click on the "Blue Cheese" header to sort, it sorts, but I lose the style on only
the "Dressings" header column. It just turns to white with black text. All other headings retain their styles, sizes, etc.... If I continue
to sort it eventually shrinks to only cover the Blue Cheese column and the "Croutons" headings moves over. This is only happening to the very first
main header. The "Croutons" header retains its stylings and column spans...until the grid is sorted multiple times it still retains its style but moves over when the
"Dressings" header shrinks. I have tried taking the grid out of the update panel and having it sort by postback. Same result. All my grid style, sort, span and size settings are done in the
the Server side InitializeLayout event. Has anyone else experienced this loss of styling, and or column size? Its a brain twister.
Here's some sample code if you can spot something I'm not seeing.
Dim DressingColumn As UltraWebGrid.ColumnHeader Dim CroutonColumn As UltraWebGrid.ColumnHeader Dim iColumn As Integer Try
With uwgData .DisplayLayout.AllowSortingDefault = UltraWebGrid.AllowSorting.Yes .DisplayLayout.HeaderClickActionDefault = UltraWebGrid.HeaderClickAction.SortSingle .DisplayLayout.UseFixedHeaders = True .Height = Unit.Pixel(400) .DisplayLayout.RowSelectorsDefault = UltraWebGrid.RowSelectors.No End With
'Add the larger headings that encapusulate the other headings With e.Layout.Bands(0) 'uwgData 'Set up multi column header DressingColumn = New UltraWebGrid.ColumnHeader DressingColumn .Caption = "Dressing" DressingColumn .RowLayoutColumnInfo.OriginY = 0 DressingColumn .RowLayoutColumnInfo.OriginX = 0 DressingColumn .RowLayoutColumnInfo.SpanX = 3 DressingColumn .Style.CssClass = "FixedColumnHeader" DressingColumn .Style.HorizontalAlign = HorizontalAlign.Center .Columns.Band.HeaderLayout.Add(DressingColumn) 'End Item Columns CroutonColumn = New UltraWebGrid.ColumnHeader CroutonColumn.Caption = "Crouton" CroutonColumn.RowLayoutColumnInfo.OriginY = 0 CroutonColumn.RowLayoutColumnInfo.OriginX = 3 CroutonColumn.RowLayoutColumnInfo.SpanX = 2 CroutonColumn.Style.CssClass = "FixedColumnHeader" CroutonColumn.Style.HorizontalAlign = HorizontalAlign.Center .Columns.Band.HeaderLayout.Add(CroutonColumn) End With
'Blue Cheese With uwgData.Columns.FromKey("BlueCheese") .Header.RowLayoutColumnInfo.OriginY = 1 .Header.Caption = "Blue Cheese" .AllowResize = UltraWebGrid.AllowSizing.Free .Width = Unit.Pixel(60) End With
'Ranch With uwgData.Columns.FromKey("Ranch") .Header.Caption = "Ranch" .Header.RowLayoutColumnInfo.OriginY = 1 .AllowResize = UltraWebGrid.AllowSizing.Free .Width = Unit.Pixel(60) End With
'French With uwgData.Columns.FromKey("French") .Header.Caption = "French" .Header.RowLayoutColumnInfo.OriginY = 1 .AllowResize = UltraWebGrid.AllowSizing.Free .Width = Unit.Pixel(60) End With
'Seasoned With uwgData.Columns.FromKey("Seasoned") .Header.Caption = "Seasonsed" .Header.RowLayoutColumnInfo.OriginY = 1 .AllowResize = UltraWebGrid.AllowSizing.Free .Width = Unit.Pixel(60) End With
'Unseasoned With uwgData.Columns.FromKey("Unseasoned") .Header.Caption = "Unseasoned" .Header.RowLayoutColumnInfo.OriginY = 1 .AllowResize = UltraWebGrid.AllowSizing.Free .Width = Unit.Pixel(60) End With
With uwgData ''Set headers to fixed For iColumn = 0 To .Columns.Count - 1 .Columns(iColumn).Header.Fixed = True Next
.DisplayLayout.TableLayout = UltraWebGrid.TableLayout.Fixed .DisplayLayout.StationaryMargins = Infragistics.WebUI.UltraWebGrid.StationaryMargins.Header
.DisplayLayout.RowAlternateStyleDefault.CssClass = "AlternateRow" .DisplayLayout.RowAlternateStyleDefault.BorderWidth = Unit.Pixel(1) .DisplayLayout.RowAlternateStyleDefault.BorderStyle = BorderStyle.Solid
.DisplayLayout.FixedHeaderStyleDefault.CssClass = "FixedColumnHeader_Sort" .DisplayLayout.FixedHeaderStyleDefault.BorderWidth = Unit.Pixel(1) .DisplayLayout.FixedHeaderStyleDefault.BorderStyle = BorderStyle.Solid
End With.
