I am dynamically building the rowedit template within a div tag inside of the Grid definition:<RowEditTemplate><div id=divHandle runat=server>Add\Edit <%=FormName %></div><div id=divEnterForm runat=server><asp:Label ID=lblFormName runat=server CssClass=pagetitle></asp:Label><div id=divFormFields runat=server></div><p align=center><button id="ctl00_MainContent_grdHealthRec_ctl00_igtbl_reOkBtn" onClick="return SaveRec(event);">Save</button><span> </span><button id="ctl00_MainContent_grdHealthRec_ctl00_igtbl_reCancelBtn" onClick="CancelRec(event)">Cancel</button></p></div> </RowEditTemplate>
Here are the respective save and cancel calls:
function SaveRec(e){if(CheckForm(document.aspnetForm,0,0)){ globalCancel = true; igtbl_gRowEditButtonClick(e); }else return false;}
function CancelRec(e){ globalCancel=true; igtbl_gRowEditButtonClick(e); return false;}
I have code to prevent the edit template from hiding if the Cancel button is not selected (default functionality). I maintain a variable to determine of the cancel button was selected. I believe I got this code form you site.
function grdHealthRec_BeforeRowTemplateCloseHandler(gridName, rowId, bSaveChanges){ //Add code to handle your event here. if (!bSaveChanges && !globalCancel) { return true; }}
This code works fine when editing an existing record, but if it's a new entry via the template by executing row.editRow() the post back occurs. Do you have an idea on what event is being executed to perform the postback? I tried to identify it with the FireFox debugger but could not. I tried executing the igtbl_cancelPostBack to no avail. This is delaying the deliverable and any help would be appreciated.
h31n1ck3 said:I am handling the UpdateRow and DeleteRow events server side.
h31n1ck3 said:I'm loading a webdatechooser control for the date value. After opening a new row to edit and selecting the date chooser to add a date, if the calender popup is outside of the Template, when I select the year/month dropdown or the date, eveything posts back and the Row Edit Template no longer displays.
The following post provides more detail on how to work around this. The post was written for WebCombo inside the row edit template, yet should apply the same for WebDateChooser.http://forums.infragistics.com/forums/p/17512/63754.aspx#63754
Vince,
I am handling the UpdateRow and DeleteRow events server side. I just identified another issue. I'm loading a webdatechooser control for the date value. After opening a new row to edit and selecting the date chooser to add a date, if the calender popup is outside of the Template, when I select the year/month dropdown or the date, eveything posts back and the Row Edit Template no longer displays.
I've been on this issue for well over a month. I've been putting it off. If you can get this solved Vince, I'll drive to Princeton and buy you lunch.
Are you handling the grid's AddRow or UpdateRow server-side events?
